I received my crossfire Pro back in may. Sadly this is the first opportunity I have been able to get around to setting it up. The table is up and running just fine. I ran the break in program with no issues.
Now it’s time to hook up plasma cutter. I have the cutmaster 60i and ordered the 9-8308 automation kit and 9-1011 CNC cable which is just a long pig tail for the CNC Port that’s added with the automation board. There is already knock out in the back of the machine for the port. It comes with a jumper harness to go from the J 609 connector on the board to the automation board. I noticed two spades coming off the automation board labeled J3 and J4. I have no clue where these needed to be wired/tapped into. This thing came with 0 instructions on the hook up. Any help would be greatly appreciated
