Anyone using the CUT50 Plasma Cutter? I’ve heard some good things about these cutters.
If you’re a CUT50 owner, would like to hear your experience with it and how they compare to other Plasma cutters you’ve tried.
There are a lot of cutters from different brands called Cut50. Are you asking specifically about Primeweld or another one? If Primeweld then they have 2 versions, make sure to get the Cut50DP for pilot arc for these tables.
You can NOT use most CUT50 plasma cutters (even if they are pilot arc) on the Langmuir tables as they are high frequency plasma cutters and cause interference.
