Ive been running the machine a bit, and struggling with hole quality on small holes. I think this is because of cut settings (ipm, power, height), but would love some advice. Current settings are based on the spread sheet for the Razor Plasma cutter, 40 amps, 65 IPM material is .120" thick
here is a picture of the top of the cut:
Do you lead out back into the empty hole? I get a little notch often inside my holes (insert dirty joke here). Maybe that’s the spot where the pierce ends?
I’m suddenly getting sloppy holes (insert joke) so I think it might be time to re-align and tighten the gantry. Seems like these machines need quite regular adjustments.
“what is your air pressure set up? how small are those hole? plasma does not cut the best quality small holes. what cad cam are u using? i have mine set up to start in the center of holes smaller than one inch. it helps get things started better.”
I know this is an old thread, but I’ve heard of this and tried to find the setting in either Fusion 360 or my machine setup.. Where do I set the system to start in the center of holes?
fusion does not have a feature to start a hole in the center. you have to do it manually when you set up your lead in. Sheet cam has that but not fusion
