I built the file in Fusion360 but when I cut the piece out of Aluminum the measurements don’t match. It shrunk by .02 - .04"
Please see attached drawings. numbers in red are actual cut measurements, black is from Fusion360.
Anyone have thoughts how to correct? I have a Crossfire which never did this. Not sure why the pro is.
If you have the gcode from the original crossfire you can compare. The G1 X and Y moves should be the same values. Did you use the same kerf width setting? Attach both gcode files to your post.
Were you selecting ‘in computer’ when running your OG CrossFire? The PRO will not run a program that has ‘in control’ comp selected. The difference being that ‘in control’ cuts on the line in Mach3 despite whatever kerf width is input. I’ve seen a few people going from the OG to the PRO experience this.
In fusion 360 I select “in computer”
I am using Fusion360 and firecontrol with the crossfire pro
This issue has not improved. Can you assist on what settings I should check and adjust.
Equipment:
Fusion 360
FireControl
Crossfire Pro
Razordweld 45 with hypertherm style machine torch
