Cut file not at bottom left corner in sheetcam (Solved: file corrupted)
Hi Guy’s need some help,this happened to me sometime ago and i don’t remember what i did to fix it my cut file from inkscape to sheetcam will not load to the bottom left in sheetcam worked fine yesterday now this today,any ideas?
when you import your file into sheetcam, you should have a pop up with 9 dots. is the lower left corner dot selected?
Thanks for the help,turns out the file was corrupted all good now
Thank you for updating us on the issue.
