I used the tractor cover @KX9M linked to up above. I take the laptop stand off (I am using pull-pins in place of the stock nuts & bolts) and lay it on the table slats. I also pull the torch cable pole out of the rail and lay that down as well. Then the cover can drop on and reaches about 2/3 the way to the floor. Keeps garage crap from landing on the table and prevents me from turning it into a flat surface storage area
