Crossfire XR Z axis lifting during cut then shut off
You might take a look at this post from Langmuir:
Another thing to do is watch FireControl and see if the IHS light turns green just prior to it lifting. There could be a break in the wire that is separating exactly when the torch is in that area of the table. It would be interesting to rotate the cut 90 degrees and see if it still happens at the same, relative spot.
Otherwise I would say there is something going wrong in the THC. You said you tried cutting without IHS but did you try it without THC? I would try that.
