Trying to set the y axis limit switches? My adjustment screws are missing the switch lever by a bout 1/8 inch? Any suggestions?
Your bolt is in backwards. Have the head of the bolt be the point of contact for the switch and see if that helps it line up.
If you can take a couple of measurements I will go out to my table and see how similar/different they are. Here is a photo of mine:
Bottom of gantry to bottom of limit switch threaded hole: 6-1/16”
Bottom of the machined piece that holds the stop to center of the bolt is 2-7/8”
Yours look like they match mine, as best as I could measure. I didnt have enough hands to hold everything and snap picture so left out the square.
I wonder if your microswitch is different?
@ben1272 You rule dude. Thank you so much. I think I’m just going to tig a stainless washer on the head of the bolt.
