I have a crossfire xr that is used often. i went to cut some parts and after the torch fires, the machine just stays where its at. i tried several things and eventually, it moved a little bit but wouldnt finish. please help
Can you jog the gantry or is it simply not moving at all? If the latter, check your power supply for the stepper drivers. If that’s not operating nothing will move.
I figured it out. It was a faulty THC circuit board thing. we don’t use that function anyways so i just unplugged it. problem solved lol
Curious ‘solution’, but I’m glad you’re running. I’ll mark this ‘solved’.
