Crossfire XR THC
Ok I’m having a bit of a brain fart or I’m just plain confused …… lol
Crossfire xr
Everlast 82i with cnc port and machine torch.
I have attached the red and black cables to torch and ground clamp connections inside plasma.
That runs to thc black and red ports
On the control unit I have torch fire on/off which would connect to the thc box ? And the cnc port pin 1/2 connect to thc box also?
Does the thc plug on back side of control unit need used? Cause if so I don’t think I was provided a two pin cable for that ? And pictures of how others have wired it with description or info will be greatly appreciated.
Thanks!
The torch on/off wire does not go to the VIM(black plastic box). It goes directly from the plasma cutter CNC port (pins 1&3) to the “torch on/off” port on the electronics enclosure.
Besides the Red and Black raw voltage wires on the face of the VIM, the only other wire that connects to that box is from the PV out port to the THC port on the electronics enclosure. The other ports on the VIM are not used with Raw voltage.
Ahh ok yeah I’m a dumb ass lol thanks so much for the reassurance and clarification
