havent used my table for a couple weeks went to sue it tonight and it is giving me this cutting voltage not detected, the LS-THC did not detect arc voltage when torch was commanded to fire. what did i forget or do wrong? table is on razorweld is on air is on.
Work lead attached to metal…
All wires in VIM and enclosure go to the correct spots…
Can you fire the torch from FireControl…
Disconnect the wire, that turns torch on, from the enclosure and short across the two parts of the plug…does the torch fire?
