CrossFire XR Misfire
^ Getting this misfire error after starting the cut. It is a simple rectangle with a small circle cut out near each corner.
It is our first cut. And this is my first time using Langmuir Systems.
I use solidworks and understand CAM, but do not have a lot of experience with various cut paths, and specific nomenclature.
Welcome to the forum! I moved your post to the CrossFire XR category as you’ll get more focused attention. AND you should be aware, as an XR buyer, you have a direct service access number with Langmuir. Look under MainSite->Help->Support->CrossFire XR
Thank you Tom, appreciate the help and active site.
What are your settings and material you are cutting? Have you tried cutting without thc on?
I recommend giving our XR support engineer, Cameron, a call. His number is (936) 235-3991
Thank you both for your responses. I will communicate with team and get these answers.
My coworker found this pdf about the y Razorcut 45 Plasma Cutter misfire issue.
https://forum.langmuirsystems.com/uploads/short-url/nm14W58lgqhrXNzSADkKNONEsUD.pdf
I contacted support using email at the bottom of the page.
They responded very fast, first asking the year of asset (3-12-21) and then stating -
"This machine will not need an upgrade.
If the software is showing you have a misfire then it’s most likely a software issue and contact Langmuir. Most likely it will be a THC Cable or the module box.
Make sure you are running the machine on a direct 220-wall plug and no extension cords. The PSI on the machine with the trigger pulled or firing should be reading 75psi on the gauge."
