Goodevening ive been having issues with my crossfire x gen 1 my motors sound like they kick on but they dont move my cnc table the lights are green in the little box, what could be my issue thanks.
@Waldo24 Welcome to Forum
Check if the motor couplers are loose.
has it worked before? does it show a connection in mach3?
Goodevening i was up all night till i got it running but i think the interface board gave out on me the light doesnt flash anymore and my computer doesnt detect the matchine, I ordered a new one should be here around 5pm but i had some questions about connecting the plasma aswell it was working last night but dont know if my wiring might of caused the interface board to give out, well I found out after putting the new interface board in that me pressing the trigger on my plasma is making the board burn out but my question is why.
which cutter do you have? if its a high frequency cutter, then that’s your problem. HF cutters will kill your electronics.
What plasma cutter are you using on the table?
What did you do that got it running?
I had the program downloaded wrong went back and redid it, but now my plasma burns out my interface board
Its some brand called warfox off 110v but ive been seeing magbe thats my issue i have a harbor freight brand 220V that ima try once my new inter board gets here
What is the part or item number of the HF plasma cutter?
It is a hobart 500548
And the one that keeps frying my interboard is a warfox EN60874
I am guessing that is the miller/Hobart 500i not a Harbor Freight plasma cutter. You can use that plasma cutter on your table.
The other plasma cutter is a High Frequency unit and can NOT be used on a Langmuir table.
