CrossFire THC Voltage Reading Circuit Schematic
Due to an issue I’m running into where the THC voltage read is way off from what I measure with my multimeter at the input to the THC plug on the control board, I decided to take a look at the circuit, since it seems like reading an analog voltage level should be simple enough. TLDR of the linked issue is, when I read it at the THC plug with a multimeter is a stable 0V when inactive and a stable 1.1V (corresponding to a correct 80V) with torch firing, but the software reads it as 0-9V inactive (even with THC cable unplugged) and sporadic but up to 20V active.
See below for the schematic I believe it is using. The chip U7 has a “1D6” label which corresponds to the TI TLV9001 op amp, and the connections all match what you would expect from an op amp except the positive input is tied to the output (I doubled checked), so maybe it’s a chinese variant of the chip where they swapped the input pins, not sure. But the rest seems to make sense, there’s U8 which is likely a regulator feeding the Analog reference (ARef) pin and positive supply to the op amp, and if the input polarity is actually swapped this represents a unity-gain buffer with low pass filter, which would make sense, and for those playing along at home it has cutoff frequency = 1/(2π√(R1·R2·C1·C2)). Analog input 1 on the THC module then reads it in, and the rest is software. All the grounds shown here are tied together, and tied to the USB shield on the board itself, but not tied to the control box common/metal.
I have yet to probe things while the board is connected and system on (and possible torch firing…), hoping to not have to get to that point, but if I do I’ll post back here with my findings.
Figured I’d share the knowledge, I think there are enough people having issues with THC voltage reading properly that it’s worth a tiny fraction of reverse engineering the proprietary board, and it’s a simple enough circuit.
A lot of people have noticed that the metal USB port is touching the case of their control box. The opening in the box does not align properly with the board and the contact between the USB shell and the control box causes excessive voltage readings on the THC. Some people have shimmed the board to align the USB with the hole and others have just shoved a piece of paper between them.
Right, like I mentioned in the other thread it’s not touching, no continuity between the two.
I don’t have a VIM, but I do not think it is wired the way you show. It is very unlikely the + input to the op amp is connected to its output. It’s more likely that you have + & - reversed in your drawing. I suspect that that op amp comes in a couple of package variations which would actually reverse the pins…
Have you unplugged the limit switch circuit and tried looking for this voltage again?
Are you becoming a ‘BigDaddy’? :thinking:
Looks like a Sallen-Key 2nd order low pass filter.
