New user - doing pretty good - have done a few cuts but am seeing more dross that I think I should. Im cutting mostly 16ga, and are using the Post Processor settings in the on line tutorial. Cutting around 70 IPM at 40 amps.
My question is what settings should I be using in the post processor for pierce height, cut height and pierce delay. I am using Cut height of .063, Pierce height of .015 and pierce delay of .5
I notice my air pressure stays pretty constant at 70 psi, but am wondering how that can be changed.
All of your settings look fine except the cutting speed. At 40 amps, you should be at least double that speed or more. You should try around 180 to 200 IPM.
