I’m about to pull the trigger on a Crossfire pro, the only thing that is stopping me is that I live in France, I can live with the shipping cost but I’m wondering if this is going to be a hassle going forward in terms of spare parts/maintainence etc
Does anyone have a crossfire and is in europe? How is it working out?
The only possible problem I see with setting a Crossfire up in Europe is the power…
Europe runs on 220v…not a big issue…but the 50Hz…compared to the design of North American 60 Hz.
You will need to invest in a Frequency Converter for the table most likely…I would check with the guys at Langmuir Systems to get thier input.
There is no reminder in the assembly instructions to switch your power supply from 110 to 220, do it first in case you forget! Perhaps @langmuirsystems should do this before shipping.
Import duty for me was 900 euros, bear that in mind.
Machine is working fine so far, two days from opening a box to cutting. Lots to learn!
Any more updates on your Crossfire Pro? Any issues, regarding power? Is it just a case of flicking a switch on the power supply unit for 220v AC?
I am thinking of importing one into the UK. I reckon it will cost me around £500 for the shipping and around another £800 in import duty and VAT at 20%.
At present they are talking about a delivery time in January 2021.
I have no problems with it, just flick the switch (first!).
Import duty was 900 euros for me in France and the shipping was pricey too but you’ll know that in advance.
I do have a power issue with my hyperthem 45xp as it can’t draw enough power from my workshop supply so I can only run it at 30 amps max so make sure you have enough supply for your torch and a large enough compressor with as dry air as you can get is my suggestion.
Hey Jamesh. Considering importing one of these. Do you have to deal with the imperial measurment system or these maschines or the FireControl Software? Sure I design parts in metric in my CAD software, but do I need to think in imperial at any later point?
Thanks Jamesh good to know. In this case that thing looks fully suitable for the European market. Looking to import one of these to Austria. Did you order it with the Plasmater Cutter or did you find a suitable alternative available in the EU? My thinking is that ordering without the plasma cutter will reduce import taxes.
Thanks for the Tip Jamesh. I did some research and your suggestion seems like the best option. I ordered a 45XP with CPC Port and machine torch. Maybe I’ll get a second hand torch, for the occasionaly hand usage. This way the machien torch stays on the table and I just need to hook up a new torch.
I am torn between ordering the Pro and waiting for the XR, but the XR is a lot heavier so shipping might kill the great price. May I ask how shipping was handeled for your Pro table? Which company and approximate price range?
Hi @jamesh.works
Glad I found your post. I’ve been trying to work out import duty to Italy before I buy. 900 euros is a killer. Did that include Vat do you know?
Cheers
Paul
Hi everyone, I bought Crossfire for CZ, I have problems with the first connection to Firecontrol, we solve with langmuir support. I hope we get started.
