good afternoon, having issues with my crossfire pro. what am i doing wrong? THC keeps tripping with pierce error, i was cutting with these settings at 2.1 pierce delay. 3/16th plate. 59 psi. everlast 52 i . 45 amps. Error keeps happening around the same area.
ill try these settings, i usually dont mess with the fusion settings just the lead in distance and then overide in fire control for whatever thickness Im cutting
I think what is happening was my pierce was too long so it got rid of the steel underneath and that tripped up the THC voltage and from there it couldn’t make the cut but thats just my guess. I havent been cutting that long
Once you have dialed in the cut settings and air pressure to the recommended values, if you are still experiencing THC errors, disable Height Control at the top of the screen and run another test cut.
If the issue subsides after disabling Height Control, then there is most likely an issue with one of the THC components. At that point, please email us and we can continue troubleshooting to find the culprit and send you replacement parts if needed.
Looks like speed is 44 ipm…. I would be more around 60 to 70. I think you are blowing the material away cutting to slow making you lose arc. Is it failing on a pierce or during the cut?
ill try that speed out next time, I increased my cutting height to 0.06 since i usually cut at 0.03 and it got half way through the cut so it was getting better with all the advice from everyone but I ended up finishing it by hand but I kept having to start from line ““
Even then it tripped the THC 3-4 times while cutting. Ill have to check all my cables tomorrow. Im also not sure if it was overheating since one of the cuts was over a minute
i was having similar problems, turns out i had my hose to the plasma cutter on a gauge port off the regulator, it didn’t have enough volume to keep up with the machine. would cut for a couple minutes then loose voltage, during the time it takes to restart the program from the last position the air hose and desiccant filter housing would recharge with air and the cycle would repeat…..
