Cross Fire - Table is dead (Problem ID'd - Dead board)
That board is pretty common in the CNC world. The blinking light means that it is ready to run but isn’t connected to the Mach3 software properly. There is a special driver that links the board to Mach3. It must be installed and set up to make it go. I can only guess that the software either got corrupted, removed, or never installed. I believe that I have a copy that you can install if you don’t already have it somewhere on your install disk. I believe that it is named RnRmotion.dll and it is in the Mach3/Plugins directory. The LED will turn steady ON when properly connected to Mach3.
This board can be bought for under $30 on ebay and amazon, providing you can tolerate a different style connector.
Instruction manual in english here:
http://173.26.168.182/files/BSMCEO4U%20Install%20Manual%202.8.pdf
Bill
