Hello again and thanks for the help. in my post processing i have an alert that says elevation limit reached. does my drawing need to be inside my table lies at this point or i had made an adjustment watching tutorials to have my torch head raise 1 1/2" was going to change that again but cant seem to pull it up again
That means you are over the 500 lines of code elevation limit of the software and its time to buy and install a SheetCAM license.
Thank You will do
As Tin said, the evaluation limit on the demo version of Sheetcam is a fairly low number of lines of code. You will need to purchase and install a Sheetcam license.
Don’t bother trying to make it raise the torch to 1.5". It doesn’t matter what you set in that field, the post processor will set the retract height at 1".
