Creating g code
…and thanks to everybody else for responding. I rank this whole process right up there with doing my taxes and dealing with city hall on building permits…
I should have taken one of my college teachers advice a little closer to heart:
“If you want to make money, own the business. But, remember you can marry more money in 5 minutes than you can make in your entire life…”
Does your table have a powered Z axis? This error is usually caused when you try to run a program with Z-axis commands on a table with no powered Z axis.
Watched the vid to make sure I followed procedure properly. It all looks good. Part of the frustration is, in the download page, it says to toggle the IHS and THC to ‘no.” I’m like. Where the feck are the toggles? What program (this a Fusion Machine option, FireControl…) and what’s the path?
Come to find out, it’s in the Machine library, several folders deep and it’s not a toggle, it’s a checkbox. Seems like the process could be better mapped out from the Langmuir folks. I understand they make the hardware and don’t support Autodesk. Guess I simply see opportunities to make this learning curve flatter. What I am grateful for is the support on this forum (which is probably why it exists). This will all start synchronizing soon (it already started). Just like my dives into PhotoShop and Excel, the power in those programs can be mind boggling.
Thanks again guys. Appreciate the help!
Reading through these topics on the langmuir forum is why I decided to buy a langmuir and join the forum.
Where they show no on here too it’s listed under the crossfire without THC and IHS
https://www.langmuirsystems.com/software/fusion
Starting at A13 they do get into talking about the IHS and THC. But they do refer to it as a toggle not a checkbox.
There’s definitely a lot of complexity when it comes to getting one of these up and running it’s kind of the trade-off for the low cost.
Seems like you’re well on your way though hopefully you’ll be able to post some stuff you’ve cut soon.
Also nice bike, I have a Suzuki DR350 and enjoy it very much.
No. That was my conclusion. The downloads have the same name and file size. Redownloaded to eliminate the possibility a loose screw on keyboard didn’t fetch right file (z-axis file). Regardless, I did not have the checkboxes unchecked.
Unfortunately, my ‘shop’ is not at my house so will have to wait and see, and pray, and drink…more…that I am one step closer to the ultimate prize.
$4,000.00, countless hours and $200 in 14 gauge sheet will produce my $12 bracket. But, I made that mf’r with my own hands!!! Hahahaha…
DAmn this is funny…gonna add this to my quotes…
Well gentlemen, we have liftoff! After another week of heavy lifting with my brain, took me and the brain cells I didn’t kill off on Saturday night to task. Went thru my work pieces to make sure all the setups, profiles, g codes and dog danglies were in order.
Indexed the sheetgoods. Set my heights and zero. Dry run went fine. Hit start and nothin…as in, no torch firing. Several error codes came up and I was ready to come unglued. Took a deep breath ( remembered I had beer in the fridge) and gave the forum one more search. Somebody else had the same issue. Switched the cutter leads at the 50:1 and off she went!
Thanks all for answering questions. TinWhisp, I owe you a beer or 3 for those videos.
