Creating a slot
Hello,
I am working on a mounting plate and I have drawn two slots.
starting as a rectangle and then I want to just fillet the corners to make them a radius.
I choose fillet and fusion won’t let me select any of the lines.
Can someone help me?
I have also noticed that it will not let me delete the slot also
I can select to delete it highlites it but won’t delete
There is a slot option already. Shouldn’t need to draw a rectangle with fillets.
Right click on drawing and click edit sketch.
I found the slot tool.
I have one more question regarding toolpathing.
Where do I find the pierce delay settings?
I went back into the tool library but I don’t see any pierce delay settings
when you post process your project you can change pierce delay there i beleive. On the window that pops up just read down the list. If this isnt what you mean sorry.
It’s not there (kerf is though). @jimt is right - it’s in the pop-up window when you generate the G-code. On the lower right side is a panel with a bunch of text based settings. About halfway down (on my monitor) is Pierce Delay and it’s defaulted to 1 (second). You can change it there. It will be different based on material thickness as thinner stock pierces faster. If you can’t see the setting your window may be smaller but then there should be a scrollbars so you can slide the settings stack up/down until you find the parameter.
Thanks for all of the help.
I was able to finish the design and toolpath and cut a perfect hydraulic motor mount in 1/2
The 45 XP is very impressive, very clean cuts with almost no dros what so ever.
45 Amps at 18 IPM
