Correct Plasma Cutter (Solved - list shared)
Could someone please provide a list of compatible plasma cutters to work with the crossfire pro? It isn’t very clear on what machine to use with the crossfire when you order one. I have had nothing but problems getting my table to run right in the last 3 years. Found out that using a high frequency machine is forbidden with this table and was the cause of most of my problems after spending time trouble shooting. Maybe I didn’t do enough research, but found it difficult to find what machines are ment to be used with this table.
Everlast 52i, 62i,82i, Razorweld 45, etc.
Just pick one. Just don’t buy the cheapest Amazon plasma cutter and expect success.
It all depends on your budget. Pick one and ask one of us before buying it.
It is not confusing at all, you just need to slow down and read. It’s in the FAQ section.
Every machine has a pilot arc. Whether it’s high frequency, or blow back is the key.
Could you show where it’s at in the FAQ? Scrolled through and still do not see where that is listed.
You just need to scroll down.
I have led you to water, but I did not bring a cup for you. This is where the journey ends.
Think you found water but missed the problem…
https://www.langmuirsystems.com/plasma-cutters
Here on the Crossfire Pro page.
TinWhisperer, thank you. For some reason I was having troubles finding it.
I see you have already been given lots of help. For anyone finding this thread you can find many pieces of support information under the support tab of the Langmuir website:
The problem is clear. You need to be spoon fed every piece of information. You will not learn this hobby if you cannot take the time to scroll through a webpage and read and learn.
If you had read my initial response to you, I also gave you all the information you needed to select a plasma cutter. You just had to do a little bit of work; perhaps Google high frequency vs blowback plasma cutting pilot arc.
Harsh? Yep. But look man, I answered your question immediately with a link to what you needed, and even added more info.
I agree with all of this.
