Can’t get my arrows in side of image
Sometimes they don’t fit inside or Fusion won’t put them there but the direction will change for inside vs outside cuts.
Yeah, but the direction rarely indicates clockwise or counter clockwise etc.
I usually let things go until the cut paths are generated. Then, I look closely at the lead-ins and make sure things are cutting in the proper direction that way. If changes need to be made(pretty rare), I’ll go back and change the arrow for the wrong one. Granted, sometimes it’s a little hard to tell which arrow is the right one to change. Zooming in or out sometimes helps in this operation… Hope this helps!
Thanks I appreciate it
KX9M nailed it. One some smaller parts you will have to generate the path and look at the green lead in lines to tell where the cut will start.
