Getting a Live voltage reading even when not cutting. The actual voltage varies and doesn’t happen all the time but when it does, it causes torch to drive into the material. All i’ve found I can do is wait for the voltage to drop. Tonight it was at 40v and took 20 minutes to fall to 0v before I could continue cutting again. Any thoughts? IHS switch is not touching z lead screw.
blow your entired z axis off with air. that happens to me when i get too much liquid splashed up on and around the torch and z axis. As a workaround you can offset your nominal voltage by that resting voltage amount to get the torch to act right. Also check your connections to your vim box.
I have blown z axis off with no immediate change.
I have re-seated plugs on vim box; no change.
I have not thought about offsetting voltage though and will keep that in my pocket for next time. Thanks @DnKFab
I would check the output on the plasma and the vim box with a meter when it is doing it .
Find out if it is the plasma, vim, or fire control. May be something you can remedy.
I put a meter between plasma ground and material set on AC and was getting ~6v while live in firecontrol was showing 30 something volts. Figured I would try here before I started the diagnoses rabbit hole but looks like I’ll need to take more notes and do some more test next time it does it.
Your plasma output is dc voltage. Check wires coming into and out of vim box.
Commenting here to help others as is one of the first Google results when searching for voltage issues. On the z axis check and make sure the pin on the back side of the IHS sensor is not touching the lead screw. I maintain an xr at a makerspace and twice now the pin has bent (somehow nobody seems to know🙄) if any parts from the ihs system are touching the keas screw it will show a live voltage. In our case it has been 5.9v. Hope this helps
@MrWelder This is most likely your problem, its what i had to do to solve the random live voltage issue
@MrWelder also I havent had any issues since ive made this change
