Hi i have a problem i can’t find out the type of connectors is on the plasma cutter for cnc ports
so i can make a custom cable
You can go to Amazon.com and do a search for: Aviation Plug Connector Male Female Panel. You can then look for the 2 pin and/or 4 pin plug. That’s where I purchased mine which gives me some spares. Hope this helps.
I have receive the plasma unit and the plugs are with the unit
