hello im having problems with my computer not being able to recognize the crossfire control panel when I plug it into the usb. im unable to connect to the fire control unit to even run the break-in programs.
hello, have you tried to start computer with USB cable Plugged in? Mine will not see crossfire without started it plugged in
FireControl would not start on my computer after it did the windows 2004 update. I uninstalled restarted and re-downloaded and installed FireControl and it works.
If you have the original crossfire you don’t use firecontrol, you use Mach 3.
