Computer requirements
What are the requirements of the computer for a crossfire pro?
Computer needs to run FireControl
FireControl
Any computer that runs Windows 7 10 or 11.
Fire control uses absolutely no resources.
If you want to start doing some drafting and design on your computer now that’s a different animal.
@BIEGZZ welcome to the forums
What about for fusion 360?
@BIEGZZ welcome to the forum.
With one addition, graphics adapter needs to support Open GL. Older PCs might not…
Thank you very much.
That is a totally different kettle of fish! Autodesk Website has those requirements. Add ‘good network’ speeds to their list.
A lot of people here use a junky old computer for running the Plasma Cutter and do the design on a higher performance system away from the metal dust and water splash you’ll get from the table.
Myself I would want at least 16 gigs of RAM. Look for a mid-range cheap gaming system.
I did a lot of the legwork recently on this subject.
You can see it here.
-TM
