I see many posts speaking of cleaning up lines on svg files imported into Fusion, but what are all of these circular things in this file, there are a ton of them? This file started out as a jpeg, then I converted to svg in Inkscape.
Try using Convertio to go from JPEG to SVG and see how it turns out:
100% improvement. Thank you!
Adding to your convertio solutions, just a heads up for the future.
As a general rule jpeg is a crappy format for turning into vectors. Due to the compression algorithm used to make them small, there are often a lot of little artifacts that get included - kind of like specs of light on a photo. A png file is always preferred if it’s an option. It’s “lossless” so it doesn’t undergo the kind of noisy compression that jpgs get.
Welcome to the forum and there are a lot of good bits of information on here.
Since you mention the map of the world, I previously posted a project on Fireshare you might like:
I have cut this in 18 and 16 gauge.
Compass Rose with Map Cut File | FireShare | Langmuir Systems
