Citric Acid mix
Just wanted to share what happens to your Citric Acid mix after setting a few months.
I run this in a tank with a pump running the whole time parts are soaking and running through a whole house water filter.
This might have had been used 3 times. When this happens it leaves deposits on the steel. Kind of a hard crusty stuff, it does come off with a stripper disk on a grinder pretty easy. Looks kinda cool in the buckets. If I keep soaking stuff I might go back to vinegar.
when i use citric acid a overnight single use is all… Well thats the way i try to plan.
That’s been my experience with citric acid, also. Over time it develops a weird slime and then progresses to the acid falling out of solution and sticking on the parts. I wouldn’t recommend it over vinegar.
That makes it kinda pricey! Unless maybe you mix it weaker due to the one time use
It is some very slimy stuff for sure.
What is your mix ratio? I let stuff soak a few days then it is just extra work to clean up. Works great for overnight.
Well it could also be the amount of metal i soak at a time too i generally when using citric acid i soak as many parts as i can submerge.
10 oz Citric acid per Gal. So my tank circulates and is filtered the whole time its soaking, and kept at about 90 degrees. Maybe that was part of my problem was soaking to long.
I think I would get the slime at some point no matter how long I soak parts for.
Only using one time seems expensive.
That is a lot from my experience. I use 12 oz per 5 gallon give or take i also do a circulation pump no filter. The last time the crust started collecting in my parts i was able to wash it off with hot water. I now try to only do 24 hours max.
I would try small batch samples with different strengths.
I do try to use straight vinegar unless i am soaking large parts.
Vinegar is the way to go, no slime. Mill scale rinses off easy after three-hour soak in vinegar.
Hey guys,
If the truth were known, P&O steel (pickled & oiled) is only fractionally more expensive than regular sheet, and it cuts like a dream.
The oil film comes off easily after cutting with a quick wipe down with a degreaser.
Sure saves a lot of the hastle of DIY acid baths.
Just so you know.
True but p&o doesn’t store well. I buy most sheet steel in bulk to get a better price. The p&o i have gotten before i still ended up acid bathing.
I am mostly soaking tube.
I used to use vinegar but switched to try citric to try it. I liked it better until this slime thing started.
Good to know, Phillip,
Was it rusting in your rack sooner than you expected?
What kind of timespan are you dealing with?
Yes with time, conditions, and or contact with something that can compromise the coating.
My garage in the summertime can frequently see humidity of 80%.
I really can’t give you a time frame because i didn’t remember nor do i buy it use it regular. I generally buy enough material to do me 6 month to a year at a time.
OK, well thanks for the heads up, I will have to keep an eye on things.
I switched to P&O this last winter after having lots of trouble with ceramic like scale on some 10ga.
My remaining sheets of P&O still look like the day I brought them in, but to be fair, we have had a nice warm and dry summer this year.
Time will tell, I guess.
A little yeast and you will have Langmuir moonshine. I bet it got some kick, Knick.:wink:
