Circles and arcs inconsistent
So I cut my first part I’m glad it was on a piece of scrap. It seems my circles aren’t circles and a few transitions are side stepping or jumping while cutting? Here are a few photos. Any hints or suggestions would be great.
Check the motor coupler set screws, when they are loose, the cuts look like what you have.
Also here is a photo of the complete part. I tried to follow the YouTube videos from Langmuir @langmuir-daniel and coot all the same settings with fusion 360 and mach3 so I’m not sure where to start to correct this, not sure if this is software or hardware.
Thanks I’ll double check them tomorrow morning
Also how thick of material is that and what plasma cutter are you using?
14 gauge material with razor cut 45
Wow thanks @langmuir-megan! I had the same problem. Here I found I must have just barely not had the set screw engaged all the way and after some use it finally slipped out.
For reference here is my before and after.
Thanks, Dan
