Every time I go into manufacture 360 always defaults to mm. Is there a way to change it so that it always defaults to inches?
I have been searching now for 3 days and still not finding a way to get 360 to default to inches. Is it not possible? Kind of a pain having to change it every time.
I have no idea but my 360 is always inches.
Click on you initials in the top right corner select preferences and a new window will pop up then go down to default units and you have to change both design and manufacture to inches and you’ll be good to go.
OMG How simple!
Thanks for helping me I was starting to think I was stuck with mm!
Its always the simple stuff that gets us…hehee. Ive never done that…
Also if you ever need to enter a mm distance and you’re running the drawing in Inches (or inverse) just type mm (or in) after the value in Fusion. So if you’re making a hole for a 5mm bolt in an inch drawing. Simple draw a circle in the dia feild type 5 mm. Boom done. This is mostly a boon for the folks that are drawing in metric and have to deal with imperial fasteners but it works both ways.
