I have tried to upload and cut 2 files now and both give me error messages. I have run the straight cut on FC just fine.
Are you using one of the post processors listed on the downloads page? If you are, can you attach your g code file so i can take a look at it?
These are the 3 files I tried to load.
F Bomb Bottle Opener.tap (6.6 KB) GP Race Works dfx.tap (63.9 KB) GP Race Works dfx2.tap (153.5 KB)
I’m using SheetCam that I bought the licence from your site.
Ah yes looks like you are using a generic Mach3 post processor which wont work with the PRO. You need to download and install the post on this page: http://www.langmuirsystems.com/downloads
What specifically on that download page am I supposed to be downloading, the Mach3 patch?
Game sheetCam is there a specific one on the list I should select before running the post process?
Hiding in plain sight… Thank you so much I’ll give it a try
did you set up a tool?
you need to set a feed rate (how fast it cuts / IPM). what material are you cutting?
I figured it out. In operations I was on the wrong layer so it wasn’t finding anything to process.
I am also getting this message although my machine speed is set in sheetcam? Any ideas
