Cant speed up jog on Mach3
I just assembled my crossfire and hooked it up. When i run the jog with the keyboard arrows it moves but not very fast. I e tried adjusting the feedrate and changing the % and nothing speeds up likenit shows in the tutorial video. Am i doin something wrong?
Did you install the Crossfire profile in the correct directory?
You need both the motion controller plugin and the profile. The slow speed is a symptom of not having done that.
https://www.langmuirsystems.com/downloads
And if you’re running Windows 10, you’ll need the patch and you’ll also want to change your G4 setting to milliseconds and use milliseconds when specifying pierce delay in the G-Code generation.
