While install the backgauge finger , the dowel pin can pass through backgauge finger, but can’t pass through upper finger bracket . Tried to hammer in with mallet , but fail to hammer it in .
Any idea or suggestion .
Did you ensure there were no burrs where you’re installing the dowel?
visually , there is no burrs . tried 4 different way to insert. same situation , too tight to insert .
How much difference is there between the hole and the pin? Maybe its a touch small?
Are the pin and the hole .3125? If it’s an interference fit, the hole should be about .001 smaller. Seems like an easy fix. If it’s drilled incorrectly, email Langmuir. If you’re comfortable taking a 5/16 drill bit, then move forward. These things happen, but I’m sure they will make it right. I’d drill it, but that’s me.
That pin is not 5/16" is it? I did not look but I was thinking it was around 1/8" and probably metric?
The drawing shows that it is 5/16 x 2. I’ll check mine in the morning.
I believe the Swiss dial veneer. Put a micrometer on it. 5/16 is just a drill away from a stopped assembly.
I see it now it does look like 5/16. As I get older, everything I think seems be wrong and it’s accelerating at a rapid rate ![]()
Thanks for all the inputs. I measured all radial runout . The pin and hole on backgauge finger are about 0.02mm . The hole on finger upper bracket is about 0.1mm . It could cause the problem . In stead of using mallet , I add a few drop of lubricant , press it on bench vise. The problem solved.
Glad it worked out for you.
