I’m logged into langmuir but when i go to fireshare it tells me to register! what am i doing wrong? thanks Joe
The Forum and FireShare do not share account information. If you have not created an account on FireShare before, then you will need to register a new account on FireShare, even if you have a Forum account.
thank you for the info!
i see the file i want to cut on fireshare and downloaded both the svg and dfx
can i take them into fusion? to see what they are set up to cut?
If the files are SVG and/or DXF, they are not set up to cut at all. The only file formats that are ready to cut are .nc and .tap.
You can import SVG and DXF files into Fusion 360. From there, you will need to do the CAM work to create a toolpath, and post processing to create a G-code that is compatible with FireControl. I recommend watching video 5 about importing files in the CAD section of our Fusion 360 tutorials, then watching the whole CAM section:
i did try to upload them both to fusion to cam work but they wont even upload to fusion.
ok i will watch them again to see what i’m missing. the wont even upload into fusion.
