Can't center backgauge gantry
Hey all,
I was trying to submit a support ticket, but I keep getting an error; hopefully you guys can help me get to the bottom of this:
It looks like the gantry rail on this assembly cannot be centered between the uprights as per the instructions; I’ve tried mounting it both ways, ensured the x-axis tube mounts were loose, and have run all the way through the back gauge install instructions trying to troubleshoot. Attached are the measurements from each side to the mounting holes, do they look correct? If so, I’d love to get some help finding where I went wrong. Thanks!
Looks like an out of spec part. I will get a new one sent out right away. I’ll send you a message.
EDIT: I see your main email now. I found your account. I’ll handle things there over the direct email chain. Should be a quick fix.
Perfect, it happens. Thank you!
