Can you make the anchor tags folks post use target="_blank"
Can you make the anchor tags folks post use target="_blank".? This way we don’t have to go down a rabbit hole and and then unwind to get back to this fourm.
Can I left turn up the ladder that fell straight sideways from the car passing by…
Only if you’re eating pancakes on a Tuesday.
Yes. But first locate the frammis valve. It connects to the dubulator pin, and you always tighten the glench carefully.
I found the answer to my own question. In the user account setup, the option to “Open all external links in a new tab” needs to be checked.
this is what you meant when you posted the thread…I had no idea…
the other way is to simply right click on the external link and choose “open link in new tab”
This works unless you live above the 49th parallel. In that case you get sent to a place above the Arctic Circle.
well it works for me…and I live above the 49th parallel…heheheheh
