At this point I’m super pissed with this Cut 45 with the CNC torch I have clean dry air I have it on the 2T setting and I have new consumables and the torch head is mounted in the correct location. I have maybe 5 halfway good cuts. My ground is right on my clean new metal with no coatings. And I’m about 1/16 above the metal with a pierce delay of 1 second. What is happening is that it pierces then moves a bit then re pierces but in doing this it leaves a gap that it didn’t cut.
how thick of material?
What is your air pressure on the front of the RW45 while cutting or piercing?
have you ever had it work correctly?
Have you tried a shorter P/D?
It also work great for multiple cuts no problem.
Thanks for getting back with me.
Metal is 3/16 mild steel
Cut speed is 85ipm at 45amps
And the air pressure is 75 to 80psi
Are you using fusion for cam?
If so share your F3d file and post the first 25 lines of g- code
