Can some cut 1/2 mild steel to prove that it will work for me
We are curently subing out a job that requires cutting .12" x .13" square holes into 1/2" A36. Can someone send me a sample that proves it is possable with the Apollo?
You would need to move up to the higher lines for any hope of that small of measurement/precision as both Apollo models only suggest “sever” capability with the two Apollo models. Sever is a very crude cut and not meant to be accurate.
The FiberSabre models boast a higher possibility. I would go to their website and pose the question.
https://www.shopsabre.com/cnc-lasers/fibersabre/
The Apollo is a 1.5 kW laser, so I’d think it could cut 1/2-inch A36 with oxygen. I don’t have mine yet, but several guys on this forum do.
Unless they changed something they have a laser module capable of 3.3 KW equipped with a 1.5 KW power supply . When they first released I asked if they may equip it with a larger power supply to fully utilize the laser and at that time they said they where testing it at higher power to see if the overall setup could handle it and if it would be safe.
Apollo Website Launch - #12 by TinWhisperer
the cost would likely climb quite a bit with a larger power supply option.
The issue isn’t the laser head; it’s the power supply. Above 2 kW, it requires a 3-phase 380–480 V input, which rules out most shops within the customer’s target market. Also, a 2kw power supply that runs single-phase is almost $4000. Another issue is that the 1500 kW chiller now needs to be increased to 2000 kW, and its price jumps from $999 to $3000.
6000$ for 33% more power maybe a good trade off for some people.
Being able to cut 1/4 aluminum would be a game changer for me at the marina.
Not to mention your Muskrat crew! They are itching to go after the bigger boats! I can almost hear them chattering about it! (And I’m currently in Maine!)
Funny none of the guys with 4x8 tables that have had them for awhile have not chimed in on this.
If I were you, I would message them as they may not come on the forum much.
So how do I message them?
do a search on here for Apollo ans you can see some of the guys that have them. Then just click on there name and message them. Maybe you can pay one of them to cut you something and send it to you. that way you can see it first hand instead of pics.
