I usually have to turn our Vulcan on and off 5 or 6 times before it will boot up. Otherwise it will just sit and hang out for hours on the loading screen. I am using the touch screen and all that to control it if that helps. Anyone else have this issue ?
I had a similar issue with prototype. Ensure that the Orange pi is being powered from the 5v power supply. They may be trying to power it from the Langmuir controller board. They may have supplied you with the cable and told you not to use it or to change it. The Orange Pi seems to be starving for power in some instances.
ahhh i do vaguely remember there being an unused cord.I will check that in a few minutes. Thank you ! I just put another element in it as well. The old one popped and burnt a tiny hole through the shield. Pretty wild.
Email @langmuir-sam and make sure that’s what they want you to try.
