Bobcad cam post for crossfire pro
Hi all, wondering if anyone else is using bobcad cam ver. 21 that has made or modified a post processor for and older version of bobcad to use on the crossfire pro. I have several posts but since I just assembled this table I’m not actually sure what the output code is supposed to look like. I’m a machinist by trade so I’m used to programming mills and lathes only.
Thanks
Check to see if Bobcad has a postprocessor for any Plasma Cutter. That would be a good first step. Did you get THC with your table?
If so, then it gets a bit more interesting, if not, the existing Post might work well enough… If not, it provides a good starting point to modify and make one.
