Hi, just finished powering up my Titan 25T but cannot get it to boot. We already removed the flash card and got past the spill screen, and onto the Bend Control software, but it stays idle between 3 and 4% load. Thanks.
You will likely need to install the .img version of the 24.1.3 patch.
Instructions to that are here: https://www.langmuirsystems.com/pdfs/Instructions_to_Reflash_SD_Card.pdf
The file for that is here:
You can leave the file as a .zip file and not unpack it. Just select the zip file when running the BalenaEtcher program.
