Bend Control screen display resolution (wrong scale)
We recently set up our Titan 25T and noticed an issue with the Bend Control screen resolution—it appears to be too large for the display. I reached out to Sam at Langmuir, and he was very helpful in addressing a few of our concerns. Despite it being late on Friday, he suggested we try re-etching the microSD card and updating to the latest beta version. Unfortunately, neither of these steps resolved the problem.
Sam mentioned he would follow up with the software team on Monday, and we’re hoping to get this sorted soon. In the meantime, I’ve also tried adjusting the resolution through the OSD buttons located behind the screen, as well as using the three-finger swipe-up gesture to access the display settings. However, adjusting the resolution didn’t seem to help—it was either slightly too large or too small.
Has anyone else experienced this issue? I’ve attached photos showing the two different settings. Any advice would be appreciated!
Email @langmuir-sam on Monday morning. Mine is not like that. I wish the die and punch menus were wider so you could read the sizes without guessing.
We’ve already notified @langmuir-sam via email and shared our latest findings. Hopefully, the software team can identify a simple solution to the issue. Once this minor discrepancy is resolved, I’ll be sure to contribute the fix to the helpful forum. So far, the assembly process has been straightforward, and the instructions and support have been excellent!
What was the fix for this? I am having the same issue. Thank you.
also have the same issue. Only happens sometimes, I just turn off and back on and it adjusts correctly.
