Does any one know what size or were to get these bearings
skateboard bearings.
There should be a number on the seal that is universal across all brands. Expect maybe some of the china stuff
There nothing on them
The other ones that are on the x and y there skateboard bearings I bought those, but these are smaller
The larger ones are #608-2RS and the smaller ones are R4-2RS. If you want the metal shielded ones just change the RS to a Z
Unless you have the
Langmuir Pro X Bones Swiss Ceramics Collab table.
Then use the Swiss Ceramic bearings.
https://bonesbearings.com/bones-reg-swiss-ceramic-bearings-7mm-16-pack
I agree those are the best type. For you cheapskates😁 or I mean thrifty people the others will work. It’s a joke guys no hate mail please.
Re Bearings, it’s not like the CrossFire rails are precision ground and hardened surfaces. The travel speed is also significantly less than even a skateboard. Sealing is important however, so RS makes sense.
You are correct a sealed bearing is better then shielded in this instance.
The bearings on the X-axis carriage (aka torch carriage) are smaller than standard 608 bearings (the kind that are used very commonly for skateboards and such- they are R4ZZ bearings.
