The Y axis bearing for screw rod went in fine. The one on the gantry is too tight. Can’t press the bearing in. Suggestions?
I had the same issue, even tried making a press with a clamp but ended up having to remove the bracket from the x axis and use an arbor press. Then it went in fine.
Hmmm…
My machine is due to arrive today, I dont have a press here
Hi All,
if you have a bearing that doesn’t fit into the bearing carrier, please send an email to support@langmuirsystems.com and they’ll send you a new one. By design the bearing should have a close sliding fit, but a light press fit is ok as well.
