Ever see that show Gold Rush with Juan and Freddy? Juan has a portable lincoln plasma cutter in his trailer which I thought was pretty cool. I’ve noticed in the Lincoln software there is a library of pre-defined shapes in the cutting software that can be quickly edited, like a circle, square, rectangles etc w.out having to design them.
Does Sheet Cam or Firecontrol have this capibility? If not I guess you’d just make a series of shapes and store them, 2x2, 3x3 squares etc…
Fusion could easily be setup for variable size shapes by using user parameters. You would need to draw each shape to generate a library. Once done, open the shape, change the parameters, go to manufacture and generate G-code.
Not quite as simple a SheetCam’s built in features, but effective.
