Now available for purchase on our online store; a purpose-built Hypertherm CPC cable to connect your plasma cutter to the CrossFire or CrossFire PRO.
Use this plug 'n play cable to directly connect your Hypertherm Plasma Cutter to any of our CrossFire CNC Machines . No need to splice into trigger wires or raw voltage to fire your torch or use Langmuir Systems Torch Height Control.
Works with:
- Hypertherm PowerMAX 45/65/85
- Hypertherm PowerMAX 45XP/65XP/85XP
To use:
Insert the CPC plug into your Hypertherm Plasma Power Supply.
Plug the longer cable barrel connector into the CrossFire Electronics Torch On/Off port.
If you have an LS-THC unit for your Machine, plug the shorter cable barrel connector into the DIV INPUT on your VIM Module.
Note: Use of this cable requires a CPC port and Hypertherm Machine Torch.
Note: If using a Hypertherm PowerMAX 65 or 85, be sure that your voltage divider is set to 50:1 before plugging into the LS-THC VIM module (50:1 is the default setting).
Wiring Schematic
