On the Gen2 controller I see connections labeled AUX1-4 (J12/J3) along with power (5V)/gnd on the connectors.
Are these ports supported by the controller at this time?
if so how are they used?
are they outputs or inputs?
do they response the M64 P1 for example?
those are/were meant for future features like limit switches but seems like they haven’t/never got around to them yet. and who knows if they ever will.
LIM1-3 would provide the Limit switch input. the board appears to have the support built-in
I image its the physical hardware and packing it is where they are at of unless there was allot of demand its not high on there list
AUX1-4 would typically be output by definition which is why I wonder if the M64/65 will work
I am pretty sure I found a list of the g codes on here in a Google drive. I saved it but really had not vetted it. Can say it is accurate. If that’s what you need I can email to you later.
Again I have not looked at them to make sure they are true.
There is no M64/65 output control in the Gen2 Controller. There are additional pins on all Gen2/Gen2XR Motion controllers for additional functionality in the future (ADD# labels). The limit switches, when released, will connect to the LIM# labeled pins.
Thank you for the documentation. that helps. I’m working on a fusion post that allows more control from within the machine and post dialogs along with some other things and this doc helps allot with that.
Sad about the M64/M65 Support,
that would be typical of how you would support them.
