Has anyone tried to swap out the plasma cutter for say a small 40 watt laser engraver off Amazon. Just trying to make the machine more versatile. I don’t see why it can’t be done.
TomWS
October 14, 2021, 8:58pm
2
If you had searched the forum before posting you would have found:
Yes I know lasers are dangerous, designing it to be safe is part 2.
I essentially want to add additional tools to the crossfire pro. Easiest would be that they would be swapped with the torch head when needed.
A laser diode for engraving/burning off a resist material to make a mask for acid etching, etc. and a sharpie. There’s a video where a guy used the sharpies with the click button to use his plasma table to plot lines on the metal before cutting - bend lines and such.
It would also be us…
Please use the search tool, it helps everyone on the forum.
