Any one run into problems putting the material supports together and installing on the rail?
Did your linear bearings have a grease plug and 2 Phillips screws holding the wiper seal in place?
Unfortunately it is a known issue that affects some but not all assemblies. Your best bet is to either remove the plug and put a dab of grease in the hole to seal it, or install a set screw. See below snippet from the assembly manual:
Sam sent me a pic of that same thing. Problem is my bearing was not the same as the pic.
I will try and post a pic tomorrow
I also ran into the Brake for the material support. One of them had the pocket machined to shallow and when installed put a lot of drag on the arm when trying to roll side to side. I had to cut about .015 - .020
then it worked like perfect.
I also found the holes were not tapped all the way to the bottom on some of the holes for the M4 socket head screws.
Damit, man, you are having a bad time with this. Hopefully, they will get these problems fixed quickly. I guess I was lucky to have mine already put together. I believe they use mine for the final software testing before shipment.
It was all little stuff that added up. It would have been easier if I had a bottoming tap but I did not.
I was lucky I had a way to cut the groove deeper in the brake part.
starting on the back gauge today! wish me luck.
I hope me posting, helps LM find some problems before others with less patience then I do, get going on here with their rants ![]()
Better send you another hat.
Ok any
One want to look on page 87 of the assy instructions and tell me what E1 means in terms I can understand stand?
So does the small end of the wedge clamp go towards the back gage finger? Or the opposite?
If you send me a picture of the part I will see if I can identify it on my machine in the morning. I really sorry you are having a hard time with this. Hopefully @langmuir-daniel or @langmuir-sam will chime in here to help you.
I will try and get a pic of it. I think I have it correctly, as it makes no sense why you would put it the other way. But sometimes things make sense after someone tells me their reasoning! ![]()
Im 99% sure that is correct
I will check it out in the morning. I could drive to work if you really need to know. Let me know.
Absolutely not it’s not that big a deal
Thank you for the pics. I got it now
Thanks Bigdaddy for the assistance - we’ll adjust our assembly guide to clear that up in the future. The slight taper on the finger and counter-taper on the wedge clamp can be hard to spot. Basically one is there to counter the other so the screws can sit on the top flat.
thats a easy fix!
Obviously its an easy fix. The point is it’s bad quality and Langmuir need to be aware of if so it can be corrected.
thats like barely a problem…
I would gladly trade machine issues with you…
